mmm im looking to get a miss fire fixed in my tune only thing its running a link ecu.. efi had any luck with these ecu's before?
Yeah man Im pretty sure they tune Link, Give whitey a call on (07) 3801 8075 an hel help ya out :blink:
  • Replies 54
Posted Images
3 months but month already gone. caught doing 160 in a mates wrx driving him home drunk from a party
he was drunk not me
gahh I feel ripped.
160 and only 3 months? Wtf...
+1
f**k oath ... I got an Automatic 6 months Suspension for doing 50ks over! PLUS a choice of 3 months or a Behaviour year ... Had to do both!
God I hope they don't make me do a good behaviour year after my suspension. If they do gooches will be axed.
I got told that because it was over 40ks a automatic suspension of 6 months kicks in, THEN on top of that you still have to do 1 point for a year or 3 months as a 'punishment' for losing the points ... :bunny: & that's what I am having to do ... I just finished my 6 month suspension but still have 6 months on 1 point, FAIL ...
yeh the cop actualli reduced the ticket to 40 under because i was driving my mate home doin the right thing was very lucky.
it was 8 points and i had 6 accumulated already so i got a choice of 3 months suspended or 1 yr good yr good behaviour and the time is going so slow
Yeah I think Ide take the 3 months
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
