Hey all my slave died out on me today :( had to get a tow. My question is are they easy to rebuild? and are the rebuild kits easily available? (south australia) or would it be better getting a upgraded one like a z32 (think they fit?),would like the car ready for monday so i can drive to work lol.
thanks
daniel
https://www.sau.com.au/forums/topic/283523-rb20det-clutch-slave-cylinder/
A slave kit is a piece of cake to install. The only problem is getting one before Monday if you really needed it. Try to contact a couple of 7 day parts stores, you never know, you may get lucky.
yeah cheers for that was gonna do the rounds and check. would getting a upgraded one be better for my ceramic cusioned button clutch? could the cylinder of worn out as the clutch is harder?
ok well found a kit at sprints $12.95 in case any1 else needed to do this,but now my master is leaking :) so that wont be done until tomorrow. Would there be anything else that would make the clutch pedal depress all the way without springing back? the spring is still connected on the pedal and none of the mounts are broken? is it just the master thats stopping this or is something else wrong?
pivot? (might be a noob question) the bit where the pedal hangs from? had the master rebuilt today but its not bleeding properly the pedal still goes all the way to the back even if you barely touch it and doesnt spring back.and when pressing on it the slave doesnt even twitch.is there a special way to bleed this system as it has that block thing that the fluid goes in then goes out in a loop and comes back and then to the slave?
ok well just had another shot at it and the master wasnt springing back the cylinder kept getting jammed at the end,it looks as if the guy who put the new seals in put ones that were too big :thumbsup:.that would explain why no fluid was being bled through.dad is going to take it back to the guy who did it and ask him WTF? will let you know how it all works out tomorrow :S
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
