i have all parts available from my stagea, silver in colour - only items unavailable is the dayz front bar and radiator rest of the car is there so let me know what you want and i will give you a price for that part, to keep the mods happy $400 dollars for the complete set of rear tail lights with free delivery aus wide $100 for the stock front bar plus postage will post specific pictures of items as requested and will put up a couple of pics of complete car tonight
https://www.sau.com.au/forums/topic/283735-wrecking-98-s2-stagea/
  • Replies 55
sorry car is in brisbane area qld
Hi Mate
I need the following please (provided it is an AWD model and not RWD?)
Full set of front and rear suspension
Front and rear brake disks and pads
10 x wheel studs
Obviously provided they are in good serviceable condition and not worn out :down:
If you are able to box it all up, I can arrange freight from my end.
Cheers
Aaron
got dayz sideskirts?sell me the pods sam
if someone can put up a pic or tell me what the pods are ..
how much for the drivers side wind deflector thingy... $40 plus postage
strut towers look fine ? you mean as in damaged or rust im guessing ? and yes i have the neo cover also undamaged - am waiting for the girlfriend to get home with digicam so i can upload the pics so will be tonight some time soon
cheers
sweet :thumbsup: getting my rust cut open in a few days, its its bad might need to replace the whole lot :D
no worries, happy to take to this thing with a grinder or gas axe so if anyone wants cuts, rear front side etc let me know, i also have a good nose cut that i bought when i was going to repair this
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
