Hello Guys,
I am selling these wheels off my 350z, bought them as "a spare part" with my car and they costed 4000 just for the rims from the dealer! I am selling them for 2200 nego. without tyres... but 2800 nego. with new brand new RE040 tyres!
I posted this a couple of days ago, but the thread is gone with the loss data I guess...
Rim and Tyre Spec:
Front:
18" x 8.0J +30 with RE040 225/45/18
Weight: 8.1 kg each
Rear:
18" x 8.5J +33 with RE040 245/45/18
Weight: 8.3 kg each
also if you want the rear tyres to be SO2 255/45/18, the price will be slightly higher as those SO2 are used for only 500km...
I believe these rims can fit R33 and R34 without any problem!
Here are the pics:
cheers,
richie
For those people who sent me PMs to express their interests, would you please sent those PMs again if you are interested in this set of wheels still? My inbox is now empty due to the database failure!
Sorry for causing all the inconveniences!
cheers,
richie
yup... Maxx is correct...
Those are NOT EVEN an option... they are considered as "SPARE PARTS" from nissan.... when I bought this set of wheels, they didn't even want to take those original 18" back... and those wheels cost 4K just for the rims!
These rims are great, the reason that I want to change is go for the bigger ones or even wider ones as the Z car has got HUGE guards!
If any one of you is interested in the price that I offer, PM me!
cheers,
richie
Ok, are they BRAND NEW? not one mark on them?
will they fit an R33 GTST?
Im interested if they are brand new and will go straight onto my car. I just dented my 2 front Nismo LMGT2s worth $800 each !
NOT HAPPY!
Sorry knore,
they aren't brand new.... if you want brand new ones, you will need to pay 4K just for the rims from Nissan dealership... or even if you import them from japan yourself... they will fit GTS-T as well I believe!
As for your case, it might be better off for you to just order another 2 LM GT2 wheels which will be better to buy those rims off me, just my honest opinion.
cheers,
richie
what i meant by brand new is ambiguous :) sorry.
i bascially mean do they have any marks on them?
can anyone confirm they will go stright onto my series 1 1994 R33 GTST ?
They probably would. I am using 18" rims from a 350z track at the moment on my s1 R33 GTST. fit straight on.
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
