Here is the final rear steering set-up. There has been alot of interest in them and they will be for sale very shortly
The sleeves shown get welded into the tube and are right and left hand thread so adjustments are easy.
Here is the whole lot ready to be fitted, its minus a few bolts and washers but you get the idea. Id fit it up but its too bloody cold outside.
The entire lot is machined 4130, as too are the arms themselves. All Tig welded with E70S2 rods.
The rose joints are the expensive part, anyone who has ever bought good quality ones (not average ones I mean teflon inserted quality ones) will agree they are pricey but worth the cost.
The joints im using are 5/8th UNF right and left handed, Teflon insert and also 4130. Break one of these and you've done something massively wrong!
Ill get photos up shortly of the whole thing installed into the R32 arse end.
There is basicly no need for any kind of HICAS lock bar or any of the factory nissan steering arms or ball joints etc etc.
  • Replies 716
Posted Images
hey Brad. have these arms been designed to bolt up the to Non Hicas bolt holes or the factory hicas bolt holes. i would assume that they have been designed to pick up the non hicas as the other hicas point would put the arms in the wrong spot for bump steer.
Hicas mountings.
The idea is to have a kit anyone can install. Gtr's don't have non hicas mounts.
The inner mounting pins are actually offset by a decent ammount, I don't just wack them together I have a set of dial indicator bump gauges. The pick ups are positioned so that with adjustable traction arms the bump steer is on average +1mm total toe in @ 100mm compression from ride height.
You probably won't find any other gtr out there with factory gear that gets close to those figures. There isn't really a right spot from factory when you change so much like we have.
There is very few people who have actually ever measured bump steer properly, the factory arangement is not the greatest, the pick ups are less than ideal, something that's slowly being corrected.
That's also the reason why I haven't used an off the shelf lock bar with factory steering arms and rose jointed outters, it would have done away with the crap outter balljoints but done nothing about the other half of the problem. This is more expensive, and has taken alot longer to develop but it's right and never has to be done again.
Edited by Risking
Hicas mountings.
Thanks for a detailed reply. id been reading and taking notes on setups that i had seen recently. UAS use the non hicas pick up and so do drift works in the UK. a mate of mine was playing with his car on a lazer aligner the other night with his rear bump steer and he found his setup with a lock bar and factory arms wasnt to far out for 0 bump steer. he did move it thoe.
It brought me to the conclusion that when i finish off my modded sub frame what ever toe arms i pick ill set up the mounting points on an aligner purely because it can all differ depending on what arms and roll centre mods are used.
your hub end design is by far the best ive seen sofar.
How is he measuring bump steer??
The only method I use is to measure ride height center of hub to guard, level thr car on jacks.
Remove the shock and spring then re fit the shock only (normally just fit an old dead shock) bottle Jack under the lower control arm raising the hub back to ride height you measured.
I have a cut up old rim that gets bolted to the hub with vertical slides welded to it.( makes adjustments easier with less rim in the way) Dial indicators against the slides and zeroed.
Raise the bottle Jack through a sensible travel range and watch the indicators.
The jig was not hard to build or you can buy them too.
Glad you like the outter mountings. there is no reason why you can't use an original hicas arm and lock bar with it either.
same process just on a lazer wheel aligner so you see the change in toe camber at the same time on a screen. very easy.
yea there may be some confusion
besides the gtr n1 race car
i have a r31 coupe with a r33 gtr rear end grafted on and dry sumped rb26/30
this on should be proper scary fast for getting me to the shops and back
thats what the above parts are for
the gtr is 100% production spec
How do those rear steer arms bolt onto the cradle?
Look awesome, ive been playing with the rear sus on my 34, interesting to see how much of a diff the traction arms make, plan to make a jig similar to what you described to fully align it properly.
Only have a HICAS cancellor in there now, and wanted to remove the factory ball joint crap.
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
