Item: Bolt On TD05 Turbo kit
Website:
Item Condition: Excellent, No Shaft Play
Reason for Selling: No longer Needed
Price and Payment Conditions: $900 Pick up Only
Extra Info: Comes with Turbo, Custom Dump pipe, Adjustable 1Bar Actuator & Braided Line
Pictures: dsc01324yla.jpg
Contact Details: Call Alex on 0403 557 352
https://www.sau.com.au/forums/topic/284240-td05-turbo-kit-to-suit-rb20rb25/
I don't know what car it was originally off.
I was running it on my rb20, don't know how many k's it has done as I bought it second hand but I only used it for 6 months and it still has no shaft play.
It made 185hp at 6psi on a bog stock rb20 (at pits on the GC which is notoriously low with its readings)
New adjustable 14psi actuator is now on it and it pulls alot harder all the way to limiter.
The turbo is steel wheeled and apparently not efficient till 17psi (so there is still ALOT of power to be made)
Have been in said car ^ On boost i think about 3300rpm? and pulls hard all the way to redline(8000rpm in rb20), this was at 1bar boost. Would be perfect on an rb25, probably have full boost at 3000rpm!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
