Hey people,
Im just after a quick answer to the above question, Im currently running 18psi with standard Internals head gasket. would I be wise to run much more boost later on if I upgrade the turbo or am I asking for trouble without a buit engine and cometic head gasket etc?
I have heard of people running 23odd psi but Im not sure if thats with forgies or standard internals
Mods are:
S2 R33 GTST
Hybrid FMIC
APEXi Super Suction Kit with pod
Custom Air box with CAI(Home Made)
Split Dump and Catco Race Cat
3.5" HKS Cat back Silent High Power exhaust
Exedy 5puk Clutch
Greddy Ex Cam Gear
EMU
Hypergear HighFlow (ATR28 G2 Profile)
Nismo 555 Injectors and Walbro fuel pump
Z32 AFM
Yellow Jacket Coils
Without more info on the turbo, you need to find out the pressure where it starts losing efficiency, or else you're needlessly generating alot more heat than you really be needing to out of the turbos efficiency range.
Ok maybe I should re-phrase my question. We all know that if you rev an unbuilt engine to say 10,000rpm day in and day out it will at some stage let go right?
So does the same thing happen when large amounts of boost is pumped through the same engine?
The max boost my current turbo can run is about 20-25psi but that's not my question.
Let's say hyperthetically I go out and buy X super turbo which has a max efficiency range of say 50psi, now surely if you pump 50psi through a standard internaled engine it will fail as it would revving it to 10k all day.
Does that make make more sense?
Knock levels will be your limiting factor, without lowering your compression or WMI you will get knock.
The combinations that can run more than say 18psi without big knock numbers on a std motor are rare [not impossible]. The more you ask for the worse it will get.
You can wind up the boost, but then you'd have to wind back the timing, so you could be no better off and probably worse than if you hadn't bothered.
But as the others have said - too many worms in the can to say for sure, its not a general rule.
as a very general rule the standard rb25 is reliable for between 250 to 280 rwkw. pick the power you want and choose a turbo to suit. no good having a big laggy turbo for 250 rwkw. if the turbo is sized right for the power and application you want then you only need to run the minimum boost required to get you there.
OP--it sounds as though you think there is a boost number that will pop your motor. There isn't. It's cylinder pressure which if effected by horsepower and knock (and a bunch of other things, but those two pertain to your question.) Like trident mentioned, if it knocks enough, your motor goes pop. Many things can cause knock including to much boost for a given octane of fuel/CR/timing/etc. The other is hp. You try making 1000hp on a motor with stock head bolts, the insane cylinder pressure is going to lift the head and the head gasket will go pop.
Think about how many psi of cylinder pressure you have when the air/fuel mixture goes bang compared to a measly little 30psi of boost. Nothing in comparison. I remember reading a lot of internet "fact" when I first started researching skylines online saying headgaskets go out on RB's at 1.2 bar. Those people had NO clue WTF they were talking about.
Cool that's pretty much what I was after, so long as it's a "safe" tune so to speak there is no majic number.
Thanks for the advice guys.... And not treating me like a dumb dumb, just one of those things I've always been curious about
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
