So i received a canary last night and am just curious about a few things.
Staggered wheel widths as i understand are a no no, correct? (i.e 7inch front 8inch rear)
Removal of the stock wing with LED brake light means i have to install a 3rd brake light in the window. Thats just my assumption but makes sence. Any one clear that up for me?
Finally, I too have been cursed by the dud drivers side electric window switch, so my window doens't go down at the moment. The Officer didn't pick me up on it just thought the inspector at licensing might?
Cheers,
Brock.
PS. if i could borrow anyones stock 33 rims or the day of inspection it would be greatly appreciated. money and/or "the carton" can be arranged.
https://www.sau.com.au/forums/topic/284532-yellowd/
For the brake light yes you do need a 3rd one in the middle.
A third brake light is compulsory on vehicles 1989 onwards, no more than 1.8m from the ground.
Mine never worked ever since I bought the car, I better get mine fixed soon :P
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4782519
Cheers for info!
Another quick one, I've heard people getting done for not having any water in there windscreen sprayer. My concern is on of my jets is only shooting one stream instead of two, are they that picky at licensing??
Cheers,
Brock.
Edited by BROCKDOE
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4782587
Yes, they can pick you for having low water in the windscreen washer bottle.
If it's too much hassle to fix, leave it and see how you go. The chances of them picking it are pretty slim but just be aware that they may ask to see it working.
The nozzle won't be hard to clear. My advice is spend 30 minutes to give it a go and cover all your bases.
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4782877
nephew is going through a yellow at the moment, they will check the center brake light but you can get them from repco . car must be 100mm of the ground at lowest point with 5 people and a full tank of fuel (cant believe that one), no staggered wheels. if you have a FMIC it must be permited
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4782946
FMIC's don't need permits
With the staggered wheels/tyres unless it's stupidly different there shouldn't be an issue, I passed quite a few times with 235/45 & 255/40 & they never mentioned anything to me, the only reason the yellow sticker didn't come off was because I was waiting for mods approval....
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4783276
Sweet deal. Water jet fixed, Installing brake light during the week. Might try get past with the staggered wheels, wrapped in fresh rubber too.
Any one have any idea about the electric window issue? Also I didn't think about this one until driving last night. I have blue lights in the foot area on drivers side and passenger side, should that be an issue??
Cheers,
Brock.
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4784419
Cheers,
Brock.
dude if ur worried about drivers window i got a spare one here if u need ,u can have it, it took me 6months and and engineers certificate to pass mine and they still said no ,so after the 6th time with screema pipes installed mind u , they past, make sure ur pod is secure and u have a lead free battery or one that is ventelated to outside ,any questions ,fire away ive heard it all from the wankers
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4784593
so scr33ma, whats the go with intercoolers. whats the trick with getting them passed. this is the only worry i have on mine.
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4785060
When I had mine done it had to be securely fixed. Others I have seen have stated that they had to be meshed.
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4785117
Power window issue is probably the same deal I had with mine (units may or may not be similar between 32 and 33.. I don't know). There's a little relay unit that's usually screwed to the door frame, that was dead, got a replacement from a wreck for cheap.
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4785168
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
