Complete 32 Gtr Wrecking, Perfect Interior, Aftermarket Parts, All Panels, Nismo Wheels,with Semi Slicks, 33 Gear Box Nismo Dash
Hi, Clutch push or pull? Price?
Also need all 4 abs-sensors and lower radiator hose. Price if not sold?
Best regards
Petter, from Norway
  • Replies 104
Posted Images
The sensors are in the hubs, only one small screw that holds them in place.
Petter
Hi Petter
I will check it out I gather you can't PM
Cheers
Hi Petter
Cheers
Radiator, shroud and lower bar is sold, yell out if you are after anything else best to PM or get in contact by phone 0408 188 777.
Cheers
Updated add, if I have mssied amyone with PM etc just yell out, Regards Taylor 0408 188 777
Cheers
Panels
Guard Driver side great condition 275
Left door includes hinges & lock and handles 160
Right Door includes hinges & lock and handles 160
Side Skirts with pods 300
Window mechanism with motor 100 each
Rear Bumper 200
Rear Reo 175
Interior, great parts for cleaning up your interior
Door Trims Great colour Front and back including all clip handles 300
Centre surround around stereo and Aircon 100
Glove Box with Key 70
Centre Console including glove box lid, strong colour 120
Leather Gear & Hand Brake Genuine great condition 80
Dash No bubbles/lifting two small screw holes easy fix, hard to notice 150
Carpet 120
Mats 100
Roof lining perfect 90
Boot complete including plastic and trims 170 no stains
Glass
Front windscreen with all wiring and aerial, genuine 475
Rear windscreen with all wiring, Genuine GTR thinner & lighter 575
Drivers side quarter glass 130
Passengers side quarter glass 130
Light & Indicators
Head Light Passenger side standard 90
Head Light right Driver side standard 90
Gauges
Greddy Exhaust gauge and wiring 120
Climate Control 90
Wheels
Space saver 45
Drive Line
Gear Box 33 GTR Good condition fits 32 as well , on Hold 900
Twin plate Direct Racing Clutch, great for performance & daily low klm 1180
Front Diff 270
Rear Cradle 350
Tail shaft 200
Drive shafts with boots 120 each
Suspension
Lower control arms factory with N1 brake ducting 100
Front sway bar 80
Rear hubs 190
Engine Bay
ABS Unit 350
Brake Master cylinder 180
Starter Motor 150
Power Steering Reservoir 90
Coolant bottle 45
4WD Computer 120
Engine Harness $600 new sell at half 300
Full Body Harness, inc fuse box, no cute TBA
Injector & resistor pack TBA
Air flow meters 145 each
HKS air pods including arms and braces 180 set
Exhaust cat back, pretty big need to measure part stainless 580
Miscellaneous
Fuel Door 60
Fuel tank 70
The 3 centre gauges, you know voltage, boost and water temp one.
It has its own wiring to it and that is what i need, the plug that plugs into it. so yea you need to cut it.
Think you can remove it? if so how much you want?
cheers!
Edited by VXL
cheers!
Hi, I want to sell the harnes complete with no cutting
Zardos I will get back to you today
Cheers
Ok, but the only easiest way you can remove it is by cuttin the wire.
Let me know if you reconsider!
Cheeers
still got the Recaro seat?
VXL, harness has already been removed without cutting so sorry not keen to split.
Seat already sold PM sent
Dash sold
Cheers
  • 6 months later...
Door Trims sold and carpert sold, feel free ot yell out about remaining parts
Cheers
Hey Taylor
Keen on Centre surround around stereo and Aircon
Can you please post -> Canberra 2905
Please pm acct details
S!N
0404 822 143
Hi Guys
Reverse lights are sold an dI will get in contact with you Sin regards the Air Con
Cheers
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
