..Finally had my safcII tuned and bleed valve installed. Peaked at 248.7rwhp @SST. So close to 250.
Noticable increase in power, especially mid range. Seems like bugger all lag now. Certainly have been having fun with additional performance. Only other mods are exhaust and filter. Is this about right.
Anyway, its about time for a cruise isnt it. Still havent been on one and would like to meet all you people.
Oh yeh. whats the size of of the bolt from the sump(r33). I am doing an oil change today and need to buy the copper washer but I cant remember what size it is. Cheers
https://www.sau.com.au/forums/topic/28461-finally/
im also wondering how much is very cheap :)
Yes when i bought the car it came with this really dodgy looking bleed valve on it .... which we played around with but suspect it didnt make any difference. My car holds boost so much better with the EBC :D Anyway it goes on the dyno at the end of this week so we'll see what she pulls!
Yep im coming on next cruise!! :uh-huh:
https://www.sau.com.au/forums/topic/28461-finally/#findComment-589889
mm never realised how much of a difference the safc or even a tune would make to the overall experiece of a car until I recently tried the 'before and after' of it's install ... should've got it on my last sil :)
14mil
https://www.sau.com.au/forums/topic/28461-finally/#findComment-590050
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
