up for sale parts for GTR32 all in good condition list as follows;
APEXI rear coil-overs multi adjustable with upper camber self adjustment $300-00
GTR32 front shocks no leaks & both work well (2 x pairs) $100-00 each set
GTR32 set of six (6) GTR coil packs $100-00
GTR32 upper left side (inner) control arm $80-00
GTR32 set of rear ball joints (vertical) NEW parts $100-00
GTR32 complete standard Air box $150-00
GTR32 Tail shaft complete and in good working order $100-00 (this is heavy so prefer Tassie buyer could possibly deliver)
Postage at buyer's expense.
That's All Folks! don't bother contacting me if you don't have the cash :D [email protected]
https://www.sau.com.au/forums/topic/284773-fs-good-quality-gtr32-parts/
GTR32 complete standard Air box $150-00 SOLD TO Dave R31
All the rest still up for grabs PM's replied ;)
GTR32 front shocks no leaks & both work well (One Pair Left) $100-00 First set sold to Limey
GTR32 complete standard Air box $150-00 SOLD TO Dave 31
That's All Folks! don't bother contacting me if you don't have the cash :laugh: [email protected]
Jump in and pick yourself up some parts guys and girls ;)
Edited by GTR092
hi mate very interested in your apexi coil overs, are they to suit any r32 gtr? are the seals and everything ok? does the adjusting spanner come with them? Im from Melbourne and need a pair asap so pm me with your number and ill call you to organise it straight away!!!
Yup to suit R32 GTR, coilovers have no leaks and my mechanic that put in and removed them said they were in great condition!
unfortunately i dont have the adjusting spanner but they arent really a must have and can be adjusted without it,
PM'ed you my contact number bud :)
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
