I've bought injectors for my jeep stroker motor from them before. Real good customer service. I recently had the injectors cleaned and flow tested after running them for a couple of years, and they were closer in spec to each other than my nismo 740's I used to have. I think since they specialize in moving a lot of injectors, they get a lot of 100 or so if the same type, test them, match up the ones that flow the closest, and get pretty good results. I think they mostly deal with OEM applications though.
Were they a Hi Flowed injector or a standard item , high impedance I gather .
Cheers A .
Off-the-shelf drop in replacement (except for plugs, they were supplied), high impedance, 550cc's.
Same as Sards.
are CA18DET injectors bigger because they'd work?
no CA18det are low impedance, CA18de's are high impedance and they are only around the 290cc mark.
have a look here, the biggest drop in are 550cc but if you want to change the rail you can go up to 890/900cc
http://www.injectorsonline.com/
P.S. Just wondering why you aren't interested in wiring in the dropping resistor, i was under the belief that low impedance injectors are easier to control at low duty cycles?
Edited by D_Stirls
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
    • Here's a pic of the damn thing
