personally i think we should block the city with as many cars as possiable :)
fcuk the cops
Block the city with as many cars as possible? Sounds like a description of the city on any Friday/Saturday night ;)
i guess in that vid most of them look like boy racers and probably are..... who would modd a carola front wheel drive, or a charade if they weren't a boy racer.... if they were legit they'd get a better car lol
Do it, but do it properly, M4 at 50km/h, or something like that, all they did was park their cars on a race track and get a photo...
and take donations etc on the way to ensure it gets on the news that we did something FOR the community in the process
Edited by iplen
lol 50km/hr on the m4..... we're not the truckers union on strike holding a go slow strike lol
