For now i've got a little bit of extra cash and seeing as my car has no zhaust I was planning on getting one...
Just after some opinions on what I should get and atm i'm only after some sound
I was told by my cousin if I was after noise I should go with a 2 1/4 Catback with a 5" Cannon and remove my mufflers.
What do you reckon?
*edit* Budget - Roughly $500
Edited by Razzle-Dazz
https://www.sau.com.au/forums/topic/285339-zhaust/
a straight pipe from behind the cat with a 5" tip muffler ...... yeah that's pretty loud! The police will hunt you for that.
and won't have much trouble finding you as they will be able to hear you from 3 suburbs away, LOL
the car is a NA. it will need mufflers to be quiet. a turbo on the other hand will be much more quiet with the same system
https://www.sau.com.au/forums/topic/285339-zhaust/#findComment-4793212
What do you reckon?
Don't do it, the only thing less classy than an underpowered car making a ridiculously loud noise, is an underpowered car making a ridiculously loud noise with a cheap overstated body kit.
BTW you could probably get the desired effect by taking a 1/8" drill to your existing muffler.
https://www.sau.com.au/forums/topic/285339-zhaust/#findComment-4802250
im running stock headers, then 2.5" piping with a leaking resonator to twin 2" tips. Its not THAT loud....but the noise is definately an aquired taste...
if you want something louder i reckon just replace the rear muffler with a cannon, dont waste money on the rest of the exhaust...
https://www.sau.com.au/forums/topic/285339-zhaust/#findComment-4806025
What do you reckon?
I reckon just run a pipe off the cat to side-dump under the driver's door. f**k the cannon, that shit muffles things occasionally.
Wind the window down and you'll be sick as.
Cant you READ?, he already said his car does NOT have an exhaust...i would've thought that would be loud enough
https://www.sau.com.au/forums/topic/285339-zhaust/#findComment-4807109
I can read actually. Can't you? The OP specifically says he wants an exhaust.
So his 2 aims are:
1. loud
2. have an exhaust
Hence why I suggested one to him that doesn't make the car too much quieter than his current un-loud setup. Telling him to leave the car without an exhaust doesn't meet his "I want an exhaust" requirement.
I'd also suggest removing the cat, which will provide even more noise, and hopefully sick flames to boot. The extra bang from flames popping out the exhaust will not only give him "some" sound, but also an "extra" sound to boot. Its a 2-for-1 deal that's only a broom handle away!
No idea why people get smart when I post things.
It helps counter-act the dumb.
Edited by scathing
https://www.sau.com.au/forums/topic/285339-zhaust/#findComment-4808340
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
