Nah man if you know the building you would know that they didnt come through the garage door. there is only one garage door and thats the one in front of the camera. They came from the building to the lefts entrance to the carpark, which suggests they know someone in that building, otherwise they would have tried just to come down the garage when someone comes in or goes out, or they could have just waited and come in from my building when someone comes in or out. they wouldnt go to the trouble of doing all that from the other building if they didnt know someone.
The footage makes me rage.
  • Replies 185
If these guys are stupid enough not to cover there faces in a surveillanced underground carpark whilst stealing a car, maybe they'd be dumb enough to continue driving the car around brisbane. I'll keep my eyes and ears open for ya dude and hopefully you'll catch these scum f#*ks!
A guy names Matt called me before and said he saw a car exactly like mine but with old rims on the M1 heading towards Tugan, may not be it but can everyone keep an eye out. Cheers everyone for all your help.
well it's probably not the only black and red two tone to be honest... they're a pretty common color combo.
very possible they either took the wheels off/sold them - they did stand out like dogs balls with all that hektik crome on them bro, so maybe they're trying to attract less attention..
Yeah I wouldnt be surprised if they did that. thats what I would do if I out myself in there shoes. but im not a f**khead like them either. thanks for all your help guys
that video made me sick to my stomach dude... really hope u get it back man, couldn't even imagine what i would do if somebody took mine, i will keep my eyes peeled on the sunny coast for u.
pm me if u find out who did it, will gladly confront them with u
peace
  • 9 months later...
Just letting people know I never got the car back. Police called me a few weeks ago letting me know that the thieves had been caught but I find that kind of hard to believe and that they admitted to the car bein sent to the chop shop and how they dont know what chop shop I have a hard time understanding.
But thanks all for the support :glare:
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
