Hi crew,
My Silvertop RB20 is stalling when the car is warm.
Symptoms include:
Clutch in revs drop too low and the car stalls.
Eventually the car wont even idle.
I have new Splitfire coil packs and rebuilt injectors, and there is no missing in the revs under boost anywhere. (for those who know my car it gets alot of air and fuel in those cylinders :P )
My thoughts on this include, battery is not being charged by alternator, battery is dead, CAS f**ked or CAS wiring was f**ked up when I extended the wiring. Fuel pump is dyeing at low revs (12 month old Bosch 023) \ when heated up?
Remember, this only occurs when the engine is warmed up.
There also seems to be a voltage drop across the cars wiring, although this has occurred since I owned it.
Another thought is the 555cc RX7 injectors (rebuilt) and the Power FC not liking the de-celeration and turning the injectors off too long \ all together? I hear there are issues with this that cant be tuned out with the hardware on the FC.
Also, I do not have an IAC setup, only AAC (although I probably need the former more) This has not been a problem in the last 12 months before the last 2 weeks that I have noticed this.
Angry saw this occur 2 weeks ago, and today my missus took the car with me to work as hers is getting a new fuel pump.
At first Angry and I thought fouled plugs or lack of fuel, but the car did it at 1/2 tank this morning.
It could just be low fuel and the pump running out its supply, but crank it and it starts straight away and drives, drive on the highway without changing gear \ letting the revs drop and no problem.
It could also have a tune factor, since I fixed a leak in my intake manifold, but it is still weird to me.
Any thoughts to add to what I have described?
Cheers
-Jez
https://www.sau.com.au/forums/topic/285496-rb20det-stalling-only-when-hot/
i reckon now the manifold is fixed the idle mixtures are whack as..... drop in fixed in a flash, and you know its not gonna cost anything.
Edited by URAS
this issue has been raised before too
one thing to look for is FPR (Fuel Pressure regulator), i am not that much mechanically minded as to how it works but i was reading a thread on Nissansilvia and a guy had the same issue with his CA18det which is prettty much a smaller version of RB's he changed his FPR and problem was solved. (however i would do the usual things first like clean AFM, throttle body, idle controller spring etc)
if i find the thread i'll link it
edit: heres the link
http://www.nissansilvia.com/forums/index.p...howtopic=398535
Edited by Sami
NO AFM, Throttle body was just cleaned...No Idle control, AAC was cleaned, as mentioned NO IAC....
ummm, not stock FPR due to AM Fuel rail...
And Nismoid STFU about stock reg, its not by choice!
Trent, Ill call you monday :P
Hey
I just went through this, Idled perfectly/strong on the cold start cycle, then hunted/died once warm. Disconnect your TPS once warm at idle and see if it idles. Mine did. Replaced TPS. I had a bad experience with a company(wrong part then three+ week wait for correct part then the plug is still wrong so we are still sorting that out) and I will PM you as they used to be a well regarded chain, now trading under another name in vic.
Best bet would be seeing is Streeter can source you one and send as they are ~150 new trade price here for the genuine part, or 200+ with a 2week wait through nissan.
Let me know how you go.
-Ryan
Trent, Ill call you monday :)
If its not the tune, then you might well have a voltage drop... in the 31 2-door?
I'm having voltage drop issues of my own when i use the windows causing it to dip a bit, nothing extra juice to the ECU wont fix though so that's something else to look into.
Why no IAC? How are you getting around it?
Yup its in the HR, low revs, and you use something that needs some current, but it has been there for the 5 years I have owned the car. There is so much old wiring in these things its hard to track down. I previously got around it with a big ass battery but changed to a smaller one, now the battery is in a box in the boot so I could always buy a large commodore\falcon size battery.
No IAC because I just didn't really bother when putting the FF plenum on, it stood out like dogs balls on top of the plenum so I decided to tune without it. I may put it back in the system yet, but Trent seems to have worked around it.
You can give the ECU some extra power, i Andrew is rewiring my car tomorrow actually and we are gonna give the ECU a better feed rather than off the loom.
So should get rid of the drop, seems rather common actually more investigation i do into it :)
Yup sounds like the right thing to do :)
Previously bloke who owned the car had a Wolf V4 in it so the loom was hacked to shit, I ended up running a new loom to the fuse box when I put the Silvertop in a few years ago, and I couldnt get a ignition source so I ran one under the dash, but there is still issues elsewhere, could be on the alternator loom, not 100%, its the 3rd alternator in it too ;)
Time for a rebuilt beefed up alt? best thing ever in old cars!!!
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
