Hello,
I am considering a used power fc, the serial number is PFCGTR33 000-0072. Application is S1 R33 GTR
I'm wondering what revision this one is, and if there are any known issues with this build. I seem to recall that some versions were better than others, so I'd like to know about this one before I buy it!
Thanks for any help!
https://www.sau.com.au/forums/topic/285669-power-fc-version-q/
this is covered in the PFC FAQ in detail, there are "no known differences" between the builds
gen 1 is RB26XX-XXXXX and gen 2 is GTR33L-XXXXX or GTR33D-XXXXX and so on...
1st gen was sold as seperate hand controller and PFC
2nd gen was sold as a bundle with the same price
so you have 2nd generation
the PFC FAQ (in my sig) also covers how to unerstand the serial # and build dates etc
Thank you Sir!
I read your FAQ, very informative, it seemed to indicate this was from an early batch of the second gen. I thought there was a processor change at some point in the build of gen 2 models...not correct?
i think from memory only the GTST had a processor change, not sure if GTR did as well
even with the processor change, its the same functionality and operationalability
the only 'known' variance between the CPU models is that older older first gen units
were slow when using 3rd party tools such as datalogit, as it must update cell by cell
whereas the new PFC units supported the faster data protocol spec
its pretty rare to find a 'slow' data xfer PFC with datalogit
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
