these items still for sale.
r34 gtt Cusco 1.5 way type-MZ limited slip differential $1000
r34 gtt Bride drivers side rail for bucket seats (e.g. Zeta III, Guardis III) $200
r34 gtr powerfc with hand controller $1000
r34 gtr boot lid silver colour $120
r34 gtr vspec rear bar, bayside blue $400
r34 gtr front bar silver colour (no lip) $350
r34 gtr front bar lower carbon lip (needs repair) $200
  • Replies 82
r34 gtt Cusco 1.5 way type-MZ limited slip differential $1000 ono
r34 gtr powerfc with hand controller $1000 ono
Garrett 2860 -5 turbos (as new) $2200 firm
SARD 700cc injectors (top feed, rb26) (cleaned and tested, very good flow on all) $650
Bump! email me on [email protected]
r34 gtt Bride drivers side rail for Bride seats with bucket base (e.g. Zeta II, III, Guardis III) $200
r34 gtr SARD 700cc injectors (top feed, rb26) (cleaned and tested, very good flow on all) $650
Price drops.. all parts are used, in excellent condition.
Added: DEFI GUAGES WATER TEMP, OIL TEMP, OIL PRESSURE, AND LINK CONTROL UNIT II AND SENSORS $900 ONO
r34 gtt Cusco 1.5 way type-MZ limited slip differential $900
r34 gtt Bride drivers side rail for Bride bucket seats (e.g. Zeta II, III, Guardis III) $200
r34 gtr powerfc with hand controller $950
r34 gtr SARD 700cc injectors (top feed, rb26) (cleaned and tested, very good flow on all) $600
r34 gtr vspec rear bar, bayside blue $350
r34 gtr front bar silver colour (no lip) $300
r34 gtr front bar lower carbon lip (needs repair) $150
r34 gtr boot lid silver colour $100
R34 GTT Quantum racing suspension coilovers, mono-tube aluminum consntruction (super light).
** fronts shocks need rebuilding. 'Swift' light weight springs fitted, from memory they are 8kg front, rear 7kg $800 ono
http://www.qrs-j.com/auto_m/t5_rs.html#con
http://www.swiftsprings.net/products-coilover_springs.html
email [email protected]
R34 GTR front bar is sold pending payment
Left for sale:
Defi guages are BF series, 60mm. light up amber. They are currently still mounted in a R34 GTT triple gauge cluster, perfect for a R34 GTT owner :huh: I'll get some pics later... come with all boxes, mounting cups w/stands, wiring looms, sensors for oil temp, water temp, oil pressure. They are as new... only had them on the car about 6 months.
LOL true salesman.
just wondering if they sat behind the glass or did they poked outside like alot of 60mm gauges. also you wouldnt happen to have a boost gauge to suit. currently got a white defi racer that would look out of place with these :down:
GTR front bar SOLD :) Carbon lower lip still available
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
