these items still for sale.
r34 gtt Cusco 1.5 way type-MZ limited slip differential $1000
r34 gtt Bride drivers side rail for bucket seats (e.g. Zeta III, Guardis III) $200
r34 gtr powerfc with hand controller $1000
r34 gtr boot lid silver colour $120
r34 gtr vspec rear bar, bayside blue $400
r34 gtr front bar silver colour (no lip) $350
r34 gtr front bar lower carbon lip (needs repair) $200
  • Replies 82
r34 gtt Cusco 1.5 way type-MZ limited slip differential $1000 ono
r34 gtr powerfc with hand controller $1000 ono
Garrett 2860 -5 turbos (as new) $2200 firm
SARD 700cc injectors (top feed, rb26) (cleaned and tested, very good flow on all) $650
Bump! email me on [email protected]
r34 gtt Bride drivers side rail for Bride seats with bucket base (e.g. Zeta II, III, Guardis III) $200
r34 gtr SARD 700cc injectors (top feed, rb26) (cleaned and tested, very good flow on all) $650
Price drops.. all parts are used, in excellent condition.
Added: DEFI GUAGES WATER TEMP, OIL TEMP, OIL PRESSURE, AND LINK CONTROL UNIT II AND SENSORS $900 ONO
r34 gtt Cusco 1.5 way type-MZ limited slip differential $900
r34 gtt Bride drivers side rail for Bride bucket seats (e.g. Zeta II, III, Guardis III) $200
r34 gtr powerfc with hand controller $950
r34 gtr SARD 700cc injectors (top feed, rb26) (cleaned and tested, very good flow on all) $600
r34 gtr vspec rear bar, bayside blue $350
r34 gtr front bar silver colour (no lip) $300
r34 gtr front bar lower carbon lip (needs repair) $150
r34 gtr boot lid silver colour $100
R34 GTT Quantum racing suspension coilovers, mono-tube aluminum consntruction (super light).
** fronts shocks need rebuilding. 'Swift' light weight springs fitted, from memory they are 8kg front, rear 7kg $800 ono
http://www.qrs-j.com/auto_m/t5_rs.html#con
http://www.swiftsprings.net/products-coilover_springs.html
email [email protected]
R34 GTR front bar is sold pending payment
Left for sale:
Defi guages are BF series, 60mm. light up amber. They are currently still mounted in a R34 GTT triple gauge cluster, perfect for a R34 GTT owner :huh: I'll get some pics later... come with all boxes, mounting cups w/stands, wiring looms, sensors for oil temp, water temp, oil pressure. They are as new... only had them on the car about 6 months.
LOL true salesman.
just wondering if they sat behind the glass or did they poked outside like alot of 60mm gauges. also you wouldnt happen to have a boost gauge to suit. currently got a white defi racer that would look out of place with these :down:
GTR front bar SOLD :) Carbon lower lip still available
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
