They can be road legal if done properly and it depends on the rules in your particular state. By far the best option is to speak with your local registration authority who should put you onto an engineering signatory. The signatory should know all the ins and outs.
In a nutshell in NSW there are rules for head clearance, visibility and access and all bars above shoulder height must be padded.
If you are planning on racing the car, you may also want to check with the relevant authorities to determine what they require because AFAIK a cage that is road legal is not necessarily approved by say CAMS.
My personal opinion (please note this is an OPINION only) for road going cars is that cages are unnecessary but racing is another matter.
Also, if its a bolt in jap cage it is highly unlikely it is approved for racing in Aus either, they need to be either developed or approved locally and jp use a smaller diameter pipe.
Unless you've got a great reason to keep it....out it goes :cool:
Dean, I would love to have one.
SKYL9, I have seen them from around $350 to $750+ second hand - you get what you pay for.
SIR33, just like installing decent sus, installing a roll cage will increase handling. Roll cages increase chassis rigidity which will provide more positive feedback to the driver.
Basically my thoughts are that for a road only car a cage is a bit of a wank, here's my 2c:
Safety benefits are questionable. The RTA doesnt like cages because they pose a striking hazard in the event of a collision type accident which is way more likely than a roll over. Sounds reasonable to me.
Its an expensive way to chase better handling and a functional cage may require some aspects of the car are compromised (eg headlining, rear seat). Compromising the design of the cage to retain car functionality sort of negates the argument that you need a cage in the first place. Also RTA rules can make it difficult to install a proper cage (ie cant have side bars across doors and driver vision/movement not to be impaired).
So the only real reason I can see for the putting a cage in a road car is because you have lots of money and want to look like an uber cool race car driver.
Of course now someone will come on here and say they got an awesome cage for $10 that retains full functionality of everything in the car, increases stiffness by 1000% and its 100% legal :P
$10, are you kidding, my mates mates mates mate got one for $1.50:p
And browny, I have already spent over 30k on my car, and I consider a $500 roll cage quite a cheap mod, but yeah, if you want a daily driver with back seats and all the rest, a roll cage just wont cut it.
Personally, I think it would be worth it, saftey wise, to have a cage in the car. Don't they say driving out on the road is far more dangerous than driving on the race track?? I have seen numerous car fatalities on the news where cars have been stolen, then run through a red light. Who survives?? the thieves....
Sorry, my rant, but if you've ever lost anyone on the road, because of some ignorant *** heads then in my eyes, if you've done everything you can to protect yourself, your better off. NOT just wank factor - a life saver in some cases.....
Did you read why I suggested they may not be great for safety on the roads?
The view by the RTA is that a roll cage is designed to protect the occupants in the event of a roll-over (rare). Because of all the bars and crap that you get with a roll cage it means there is more stuff that you can bust yourself up on in a collision type accident which is vastly more common. Hence in the majority of cases a cage presents more of a safety risk.
Racing is a different situation as there is much greater chance of a roll-over.
THEN add a roll cage, and you are cooking. Besides, I can guarantee that all those pretty DoLuck bits added together probably cost more than 2 roll cages - nevertheless, EVER bit helps, its all good.
for $500, a excellent condition steel cage or an alloy one in decent condition with cosmetic problems. I have seen full chrome molly in near perfect condition second hand for $750.
you're probably right, but you can probably get cheaper if you buy a different brand. Do Luck isn't exactly cheap :)
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
