Hey guys...
Just wondering if there is a company out there (in Vic) that help setup your car's suspension and overall for circuit racing...
I have done a few Calder practice days, but I still cant get it right, and I know the car has a lot more to give...
I'm running Tein Mono Flex, adj sways, few set of different spring sets, adjustable arms...
Unfortunatly I am not consistant enough (lap times) nor expereinced enough to fine tune it.
I the past with my old basic/cheap set up I could do 10-15 laps within 1-2 seconds of eachother... Now I am all over the place..
I've tried Centerline, who gave me a starting point but, I need more help...
Any recommendations...
What times are you doing? Calder isnt really a good test track. Are you going quicker? Your times being all over the place could be the fact that you have better corner speeds and you are not getting too mcuh heat into the tyres so after a few laps your grip is going??????????
If you have tried Centreline then i would be sticking with them, or there i always Racepace who build the states quickest GTRs and also Tru Track.
The reason why I do my testing at calder is its close and cheap (practice session days)
I raced the car a few years ago and had it running 99.9% of its capacity, very consistant ... beautifully...
I then had the car "modified" substantially including adjustable suspension... etc....
The car handles like a pig... I am fighting it all the way around the track ...
The problem is when someone asks me what is it doing wrong... my response is alway "dont know, but it sucks"
when I used to race it, its was sweat, now its a battle and a chor
TruTrack is just around the corner from my work, and my mono-flex needs the spring perchs and the damper adjusted, alignment and rideheight is already done.... would they have a base line kinda setting that they would go too that I could work from? or am I best off with Racepace?
What coilovers are you running?
I am running custom revlaved and springed Teins from Racepace. I had an alignment at Tru Track around March and the brief drive i had was good. But i have not tracked it with their wheel alignment, But Tru-Track have done plenty of the alignment on SAU track goers cars. I will know later this year when i get home and start punting the thing again
They have GTRs doing 60-62 seond laps at Calder so they ovbiously handle well. When my car was at Tru Track they said to me they liked the custom Teins that come out of Racepace
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
