Clearing out the shed, and have a few bits and pieces that I need to get rid of
Set of Apex'i shocks, with 1 1/2 inch lowered and nice and firm Apex'i springs. Shocks are damper adjustable, and in really good condition - only selling due to having fitted a set of Coilovers - $550 - offers considered
Trust/Greddy dual pillar mount gauge holder, used for about a month, not a cheap copy, but a proper Trust one, with box in as new condition - $130 *SOLD*
Stock R32 turbo, in good condition, never boosted above stock and very minimal play in bearing etc, with water banjo fittings and stock dump pipe - $250 offers considered
Set of stock R32 rims, with a few scrapes on them and newish fronts and 60% rear tyres - $400
Stock fuel pump and holder (complete) with stock pump that was working 100% when removed - $150
Speco oil temp gauge - mechanical guage with fitting for sump plug, used - $40
2 x 18" Michelin slicks from GTP car (look like about 265x35) used but still good for a bit of fun $50 (Adelaide only)
2x 17" BF Goodrich slicks, of GTP car, 235x45, used bit still ok for a bit of thrash $50 (Adelaide only)
Used R32 GTST front brake rotors, need machining but otherwise ok - $70 *SOLD*
New set of Bendix Ultimate front brake pads, suit R32GTST (not sure but also might fit R33 and S14) $50 *SOLD*
Two fog lights out of R32 GTST Type M in good condition, working with globes - $70
thats about all I can think of for now, will post others stuff once I think of it
post email adress if you want pics of any of the items
Thanks, Chris
https://www.sau.com.au/forums/topic/28598-r32-bits-and-pieces/
Brody - pads are brand new, sealed in plastic. The rotors are in pretty good condition, need a machine though as they have a bit of a lip on the outer edge. I was gonna do that but got slotted rotors and racebrakes pads instead, hence why I have a set of new Bendix pads for sale
Enrico - Will take some pics on the weekend and email them to you, they are in ok condition, I was going to use them but never got around to it
All PM's replied to
I am off on holidays as of monday, but still will be able to check PM's etc, but I apologise if it takes a little longer than usual
It will give me plenty of time to get frieght organized for those of you who have bought some of my parts
Regards, Chris
  • 3 weeks later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
