Details:
Nissan 200SX S14 series 2 1998
Blacktop SR20DET with VCT, 5 spd manual
Genuine 180,XXX kms on it
Blue colour
Tinted Windows
JDM kouki front bar with fog lights
Jap 17"x8.5" and 17'x9.5' +15 all round
Carbin fiber bonnet
Engine:
Pod filter
Gready Front mount intercooler kit painted black all piping aswell
3 inch Turboback exhaust
Turbosmart duel stage manual boost controller set to 12psi and 15psi
Exedy Heavy Heavy duty brass button cluth around 500kms old
Dump pipe
Apexi Power FC tuner by RE customs making 202rwkw on hight boost and around 175rwkw on low boost(never reali go high boost as low is all you need)
R33 GTR fuel pump
Cusco 2way LSD
Suspension:
Kei Office front coilovers (9kg spring rate, 2way hight/damper and camber adjustable)
Tein Rear coilovers (8kg spring rate, damper adjustable)**waiting for luke fink to bring them down to me have king springs in rear atm :(**
Bad points
VCT chain is a little nosey re checked it said its all fine around the $500 mark to replace just havnt had time.
Selling as i have a ve ss as my daily and this is just sitting there picking up dust
Price: $12,000Quick sale (can bring price down if i remove some parts)
I am open to offers as long as they arent low ball offers.
Pics coming soon otherwise i can mms u if ur reali keen
0433663833
https://www.sau.com.au/forums/topic/286025-s14-series-2-1998/
here some phone photos till i get time to bring in my diggy... lil dirty but u get that lol
wheel it comes with are the ones on the front of the car
Edited by evlgtr
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
