RB20det gearbox $300
RB20det fuel rail with injectors $30
RB20det standard manual ECU. $50
RB20DET airflow meter $30
K&N Pod filter, good cond, $15
RB20/25 low mount stainless manifold $50
R33 skyline genuine floor matts in mint cond $100
aftermarket steering wheel with S13 boss kit $50
RB20det blow turbo $20
Mini turbo timer, brand new etc.. paid $100 from autobarnz, want $50
Spray pump, good for hektik intercooler spray or whaever you desire. model is flowjet 12vdc 2.34LPM $50, cost hundreds new.
https://www.sau.com.au/forums/topic/286103-mega-random-part-sale/
HOW MUCH TO POST TIMER TO CENTRAL COAST
Nothing wrong with it, only thing i don't like is the collector on the inside is a bit rough, but i can port it out for extra $10 if need be.
I can post the turbo timer for $5.00
K&N pod is 4inch dia, and yes you can clean it with the K&N recharge kit.
Edited by Fluroman
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
