1989 BNR32 GTR
Silver
87k kms on the clock (I believe the car now has 127k kms genuine)
Melbourne, Victoria
Price: $18,000 will consider trades
Fruit =
Apexi Power Fc with Hand Controller
TRUST pods
Jim Berry clutch
TIEN coilovers
Fujiturbo front pipe and 80mm exhaust
GReedy gauge set
17 inch JDM dish wlloys (I believe they are Osimoto? brand)
Clarion mp3/cd USB stick headunit, new speakers and 700w amp
central locking/alarm/imoboliser
HKS Turbo timer
GReedy dual stage boost controller
cam gears
new hoses etc
N1 bits and pieces
I am the first to own this car in australia and had all major service work done upon delivery by MPC in melbourne, for the next 2 years I drove the car daily and added 15ks to the clock, interior and body is above average
In that time I have service her every 3,000ks and replaced rotors, pads, rust proofing, front bushes, and coolant hoses and added the PFC and cam gears
Car was dyno'd at 180awk when complied and after tuning set to 0.9bar making 230awk by Autoteknik in Hiedelberg and has only been a street car
Needs a head gasket as oil is getting into the cooling system and has been stored for 9 months
Car has long reg, roadworthy and runs and drives beutifully
Selling because I dont have the time to play with cars :|
I can and will keep it so dont loball me
http://img.villagephotos.com/p/2004-8/814527/1711964
http://img.villagephotos.com/p/2004-8/814527/14-Jun-2006.jpg
thanks
Will consider trades +/- $ either way
https://www.sau.com.au/forums/topic/286118-silver-r32-gtr/
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
