As title states:
Im trying to find a CD/DVD burning program for Mac. Its for a friend so it needs to be something relatively simple to install/use and yes -free! ;)
Im not a Mac user myself so i got no idea whats out there; would that copy of Nero i got somewhere in my study be Mac compatible?
10 points if you can supply a link too :down:
https://www.sau.com.au/forums/topic/286526-cddvd-burning-program-for-mac/
I use Toast (titanium) for my Mac, founf it to be really good or for file conversions try Visual Hub all available from the above cough,cough store free of charge!!
