Guys,
i'm "tossin:bahaha: " up what mods to do to my car R33 GTR. At the moment it's pretty stock "bar the cat back exhaust, pods & turbosmart bleed thingy valve". I have ordered the Power FC & Hand Controller and about to contemplate the following mods... what do you think, as I've heard various opinions from reputable performance shops.
PS: I'm not after qtr mile times, sprints etc.. just a reliable "every second" daily driver that goes a bit harder & breathes easier than stock.
Mods to go with existing - Pods, Bleed thingy Valve, Cat Back exhaust.
1. Power FC & HC (which tuner - In Vic)
- I know many will say ICE, but I was also told the man to see is Vinnie from Sti Dockland "x owner of BGT - AKA Hyper Tech - AKA Apexi King". Also told without software hand controller only accesses about 30% of the functions.
2. Front Pipe
- I know a good exhaust shop that's done most of my cars. Thinking of getting a custom made rather than Brand Name.
3. Cat
- Told the stock cat is excellent for my basic mods.
4. Heatshield for Pods & CAI
- Goes without saying hmmm.
5. Adjustable Cam Gears
- I'm a little worried here again hearing various opinions from tuners. Most say it's the best choice, ICE have re manufactured GTR Gears for 220 change-over. But I'm worried if there not centred correctly or done properly whether they could damage the motor.
Thanks
https://www.sau.com.au/forums/topic/28660-gtr-mods-help/
Can I please suggest an electronic boost controller? It will help you turbos spool up much faster as it doesn't leak air going to the wastegate actuators before peak boost is reached like bleed valves like to do...
Also a nice set of dump pipes off the turbos are always good too!
https://www.sau.com.au/forums/topic/28660-gtr-mods-help/#findComment-592404
Don't do this to me Merli :P My initial order was Power FC, HC & the EBC. Spoke to Nigel from ICE & nearly every one else said the Apexi EBC was shy-zen-howzen because it only had 1 solenoid. They all said the best was the Profec B or something like that. But they could fix the bleed valve to work just fine.
I was told not to worry about these unless I'm looking at hi-flowing or changing the turbos.
https://www.sau.com.au/forums/topic/28660-gtr-mods-help/#findComment-592416
Originally posted by meshmesh
Don't do this to me Merli :) My initial order was Power FC, HC & the EBC. Spoke to Nigel from ICE & nearly every one else said the Apexi EBC was shy-zen-howzen because it only had 1 solenoid. They all said the best was the Profec B or something like that. But they could fix the bleed valve to work just fine.
Sorry Simon :bahaha:
It's true that dual solenoid EBCs like the GReddy Profec B, Blitz SBC-ID or HKS EVC4 will control boost slightly better than a single solenoid EBC like the APEXi AVC-R or Boost Kit for PowerFC.
Although that may be the case, but if the Apexi EBC is crappy for having only one solenoid, where does that leave the bleed valve? ;)
There is nothing inherently wrong with bleed valves. They'll increase your boost, albeit a little slower than an EBC and spike at little more, but I appreciate that you want the best for your car, and that's why I proposed the EBC :)
Secondly, turbocharged cars rely on the biggest, free flowing exhaust possible to reduce backpressure so the exhaust wheel isn't restricted at all and can spin as fast as possible, creating more boost and increasing efficiency. To this end, it is better to replace your entire exhaust, turbo-back with a larger diameter exhaust, including the cat with a high-flow item. If you see the dump pipes off a GTR, you can immediately see how restrictive they can be compared to, say, HKS dump pipes.
Cheers,
Andrew.
https://www.sau.com.au/forums/topic/28660-gtr-mods-help/#findComment-592426
"- I know a good exhaust shop that's done most of my cars. Thinking of getting a custom made rather than Brand Name."
Why bother? The major multinational japanese companies (HKS, etc) have put a hell of a lot more blood, sweat, tears and R&D into their products - as opposed to something knocked up in someones shed (I don't care how good they can weld...)
https://www.sau.com.au/forums/topic/28660-gtr-mods-help/#findComment-592438
Jeez man, don't hold back. Tell us how you really feel... :)
https://www.sau.com.au/forums/topic/28660-gtr-mods-help/#findComment-592453
Hey, no offence intended - just "calling a spade a spade".  Custom work is great when you need something special fabricated - but when there's a perfectly good product on the shelf - why bother?
Nah mate I'm not offended, I was just having a laugh at you sticking the boot in...
https://www.sau.com.au/forums/topic/28660-gtr-mods-help/#findComment-592470
My reasoning is often you can get something custom made thats exactly the same as a name brand for 1/3 of the price. Or for say cam gears - why pay $900 for a couple of bits of aliminium when you have some perfectly good ones that can be custom modified for $200.
https://www.sau.com.au/forums/topic/28660-gtr-mods-help/#findComment-592478
$900 for cam gears?? That might be aussie shop prices but no one I know of has paid anywhere that much for cam gears.. I got my HKS cam gears for just over $400 delivered to my door.. I personally wouldn't go stock gears that have been modified..
Mesh, really depends on your budget. I run the PFC with boost kit and have had no problems at all, holds 1.2 bar no worries and I can use the H/C as a boost gauge as well...
Mick, just out of curiousity what are your cam gears set at? Adv and Ret???
Cheers
Brett
https://www.sau.com.au/forums/topic/28660-gtr-mods-help/#findComment-592763
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
