Got a bunch of things taking up space and they need to go :P
All items are located in Sydney. Pickup preferred, but willing to post at buyers expense
Item: Weather shields
Condition:Good
Price:$80
To Fit: R33 skyline (2 door)
Comments: I had all the clips but recently moved so not sure if i can find them now.
Item: HKS Mushroom Pod Filter + Adapter
Condition:Good
Price:$70
To Fit: Anything
Comments: The induction noise was too loud for my liking, so replaced with stock air box. Filter needs a clean
Item: East Bear Style Grille
Condition:Good
Price:$80
To Fit: R33 S2
Comments: Bought off ebay for 120, but i didn't like the way it sit and couldn't be bothered figuring out how to do it properly
Item: Series 2 Sedan Headlights
Condition:Good
Price:$500
To Fit: R33 S2 sedan/coupe
Comments: Came with the car, but have changed them over. Comes with all plugs and wires. Left light is missing a lower tab, but it doesn't affect anything as all the grilles i've used have not used it.
https://www.sau.com.au/forums/topic/286712-garage-cleanup/
Hey buddy quiet intrested in weather shield but curiosity needs to kill the cat first...
Do they fit S1 R33's? if so have u found all necessary bolts n clips for em?
n where in Syd u located at?
-JAi-
https://www.sau.com.au/forums/topic/286712-garage-cleanup/#findComment-4817671
All items are located in Yagoona, in Sydneys West.
Unfortunately i don't have any pics of the grille on the car, i'll try to take some, just been pretty busy lately. You're welcome to come and test fit it if you like.
Pretty sure the weather shields would fit an S1 coupe, haven't had a chance to look for the clips though :)
Cheers
https://www.sau.com.au/forums/topic/286712-garage-cleanup/#findComment-4818062
  • 1 month later...
  • 3 weeks later...
  • 4 months later...
  • 1 month later...
  • 4 years later...
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
