to buy it (if the avove mentioned dont have it)
http://www.redlineoil.com.au/reseller-locations.asp
i went to the bondi place and actually picked it up at the newsagency on the main drag which was owned by the same dudes
then just get joe shmoe at your local petrol station workshop to chuck it in for you (quite easy i believe) and save on huge hourly rates of a performance workshop or better yet do it yourself if you've got the know-how
https://www.sau.com.au/forums/topic/28676-redline-oil/#findComment-592540
Thanks guys!
I spoke to a few in that list b4 hand and some had no clue...
Ive found a place now that will do a gal for around 110, and will get the local mechanic to do it.
Unique had it for $30 a litre and charged $98/hour
CRD had it for $25 and grunted "just leave it herr and come back later"
Didn't really want to do it myself...gbox seems a bitch to get to and i can see myself spilling it all over my driveway :)
https://www.sau.com.au/forums/topic/28676-redline-oil/#findComment-592584
Just a note for doing it your self.
At times the filler cap for the gearbox is a biatch to get off. I had to use a braker bar to get my one off, if I didnt have a hoist I would have had a hell of a time.
I would get your local mechanic to help. Will only take a few minutes for them to do.
https://www.sau.com.au/forums/topic/28676-redline-oil/#findComment-592659
:werd:
It's a biatch to get off !
https://www.sau.com.au/forums/topic/28676-redline-oil/#findComment-593035
:werd:
Heh its all in now, though it took them forever to get the nut off, had me worried for a sec :)
To be honest I havn't noticed anything special yet. Still feels just as notchy and 2nd takes abit of time to get in when giving it. I've only done 20k, though I expected it to work straight away(?).
He had 2 juniors do it and while pumping the oil in, the hose came off the pump, leaving the other with nice thick blue oil all over his face ;) was funny, though not considering the price of the oil :)
https://www.sau.com.au/forums/topic/28676-redline-oil/#findComment-593104
i put in the ultra lightwight (yellow) over a thousand ks ago, when i first put it in there was no difference at all, but now, there is a definine difference, it never crunches into any of the gears anymore, so yeah u really have to give it time :cheers:
https://www.sau.com.au/forums/topic/28676-redline-oil/#findComment-593807
Its only hard if you have muppet arms :D
Sumo
https://www.sau.com.au/forums/topic/28676-redline-oil/#findComment-594251
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
