hey guys,
popped the car (r32) up on a hoist today and sussed out the struts (as there rather firm, thus i don't believe there stock, not that i have ever found another skyline with stock suspension to compare it too.. haha)
all i can tell is that there black and have "nismo" plastered on the side of each strut.
there quite firm as well. not solid, but firm enough to get more or less no roll around corners.
anyone have any ideas where they came from?
nb. the springs are black as well.
https://www.sau.com.au/forums/topic/286795-nismo-struts/
thats odd, because when you said they were black i thought yep they are stock ones but then you said it has nismo written on it so now im not sure. i have nismo s-tunes and they are silver and the springs are red.
edit: i forgot to add if they are nismo's then they will be at least damper adjustable. on the rears is a little knob you can turn with number 1 to 4 and the fronts have it on top of the struts.
https://www.sau.com.au/forums/topic/286795-nismo-struts/#findComment-4812938
i got some pics of them that im uploading to tinypic. (ill post them in about 5min, probably by the time i finish writing this), the top of the struts front and rear are just a threaded bolt with a nut on them. im assuming its just the shocker bolted into the strut top?)
i uploaded a pic of teh car itself, its sitting on 17" rims, yet seems to be VERY high, specially for a skyline (lol).
the struts do look black, GRANTED, they are probably very dirty, - i just shoved my phone under the car and took photos, the flash is pretty extreme so everything looks shiny
so the next question is, is for me to lower it, can i just buy lower springs from ebay listed for an R32? or are the struts different?
and the car has already got some pretty noticeable camber, how much does lowering the car effect this?
EDIT:
took a pic of the strut top. sorry about the large sizes/shit quality.
Edited by haleja
https://www.sau.com.au/forums/topic/286795-nismo-struts/#findComment-4812998
do standard R32 springs fit into the nismo struts? or are they a 'special" size?
the car looks raised imo, maybe the struts are longer and they got standard height stiff springs.
i only asked about camber as i know you get camber the lower you go, and the car already has negative camber. as much as i want to lower the car, its not really practice if camber goes through the roof.
big questions are.
1. do stander diameter springs fit in to the struts,
2. how much would camber change if i drop her an inch?
https://www.sau.com.au/forums/topic/286795-nismo-struts/#findComment-4813106
ya know, after looking at the rear of the car for a while, i recon the camber isnt actually taht huge, its just the fact that it has a standard rear bar on it, is quite high, and the wheels are 17" by 9".
so the angle (even though minimal) shows up quite a bit.
https://www.sau.com.au/forums/topic/286795-nismo-struts/#findComment-4813258
yeah the struts look good, just demolished boots lol. i dunno what springs i wanna put on there. tein s tech seem the way to go, but i dunno if they will be too soft for me. otherwise ill prob get some custom made ones, i cant find a place to buy them other than ebay.
off topic, anyone know any good online parts dealers based in AUS?
Cheers for ya feedback scotty.
https://www.sau.com.au/forums/topic/286795-nismo-struts/#findComment-4813374
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
