Looks to me like its got vac hoses coming out one side and plugged in to a factory loom?
Could be some sort of boost controller.
Cos you can see that your factory boost solenoid is unplugged, and the lines have been cut. That would be my guess.
EDIT then i noticed the blue thing that says "Dual Stage Boost Controller"
So im at a loss :) Unplug it and see what happens. haha
Edited by gotRICE?
https://www.sau.com.au/forums/topic/287281-what-is-this/#findComment-4818217
Its a megaphone to make your dose louder, its a microphone that amplifies the sound of the flutter from the pod and pumps it out through a speaker hidden in your front bumper at 3 times the volume lolz.....jokes
there are 2 plugs unconnected just above it, what used to be there? dunno gtt's but is that where the original oem actuator was? perhaps its some form of boost control unit like a filter
https://www.sau.com.au/forums/topic/287281-what-is-this/#findComment-4818587
Don't think it's anything to do with boost control, and the plugs above are unpluged from the stock boost solenoid when the dual stage boost controller was hooked up. It was bolted to that hole just to the right of the pod, anyone else have anything like this there or just me? lol.
https://www.sau.com.au/forums/topic/287281-what-is-this/#findComment-4819074
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
