My r32 afm wont work, so i ordered a z32. Now, ive been told that the z32 wont work on my car. Do i need a aftermarket ecu for it to work?
You wont be able to run the Z32 on stock ECU unless you get it remapped mate :yes:
nope... wont work. get an apexi SAFC 1 or 2, easiest way to run z32 afm.
can you explain to me what it exactly does? air flow converter? how much does it cost, how easily available is it?
so, your basically telling me i need to change the computer in my car to the z32 to work? how effective are the piggyback ecu's?
Edited by IM-32-FK
Get your ECU remapped. Will do a much better job than an SAFC
can you get a stock r32 ecu remapped? shouldnt i just buy a aftermarket ecu?
sorry if im asking stupid/obvious questions, but i have moved from N/A to Turbocharged, and boy, there is so much stuff to learn that its overwhelming.
safc might not be the greatest way... but i did that because i couldnt afford to have my ecu missing for a week. i bought a safc on ebay, installed it on the weekend, got it set up and road tuned by myself with an a/f gauge before i had to drive to work on the monday.. and any changes i made after could be retuned in.. not have to send the ecu away again. now that im selling the car.. i have removed the bits and pieces and the safc and everything is as normal.
aftermarket ECU or remap is the best option though.
Nistune will cost you $200 and probably $100 to get some one to adjust the afm setting or you can tell me what ecu model you are using and i could send you a stock tune adjusted to suit the Z32
Just go with the nistune setup, it's cheap and you can change your AFM size easily with the Nistune software while keeping that factory ecu.
Seconded. stealthy and easy to retune.
woah, you can connect your ecu to your computer and change the ecu settings through your computer? the r32 ecu just sits on the bottom left of the passenger seats just right next to the feet right...?
Buy the Nistune chip software and cable and you have a real time tunable ecu
id rather not tune it myself, as im still new to the tuning scene. Besides, im not going to fork out $400+ just to get my z32 working. How much does it cost to get your car tuned at a workshop?
Tunning the car just to take the Z32 will require it to be chipped and that will probably cost a couple of $100 to start with you are better off paying the $400 and adjusting this single setting your self very easy to do 1 drop down menu involved and it will at least mean when you do want the car tuned properly you are just paying for dyno time
i got my nistune supplied and fitted at status tuning, and they did the plug for the z32, i think it came to $700 or $750.
couldnt be happier.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
