Ok I've got a fire-extinguisher, a small pelican case with some basic tools, a hydraulic jack, and a spanner for my wheels nuts in the boot.
So when I go around corners I can hear it all sliding about.
I'm not drifting or 'fishtailing it'....just driving normal. :whistling:
I'd appreciated some help with this pressing matter. :(
/yeah I know I should get a mount for the extinguisher but I've not got around to sorting that out yet. I was gonna secure it to a home-made bracket attached to the seat bolt rails.
https://www.sau.com.au/forums/topic/287580-securing-stuff-in-the-boot/
There'll be a sub frame you can secure the extinguisher holder to (that big plate that goes behind the passenger seats even ?).
For everything else, get a box :whistling: dont even worry about securing it, it wont move if its all together.
Edited by Nic_A31
fire extinguisher in boot = Fail by the tme you get outof car open boot fire has taken over
Mount the extinguisher inside cabin under drivers seat or at least within reach of driver with seat belt still done up
rest of stuff get a small tool box and glue non slip matting to the bottom of it
Good idea...or velco or something?
Or could get a big thick piece of foam, cut it out so it fits in my boot, then cut out the shapes of my tool boxes etc and slot them in?
I do wonder about the virtue of having a jack and even a spare tyre. I mean firstly it is extra weight :) , and I've got RAC breakdown cover anyway, and I don't drive much outside the metropolitan area. I got a puncture last week so I figure that make me now very unlikely to get another one for years also.
Now that you've said that, Murphy's Law will have it that you blow a tyre next week.
If you're gonna mount the fire extinguisher inside, go drifter style, passenger side of the gearbox.
ha ha yeah.
No way do I want to drill holes through the floor pan or whatever.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
