Hey guys. I'm in Adelaide and planning on road tripping to Perth next sometime early next year.
I was just wondering, in the middle of nowhere they've got this "opel fuel" stuff. What exactly is it and will it be ok for the Stag??
https://www.sau.com.au/forums/topic/287674-opel-fuel-in-the-stagea/
Gee there is so much crap goes on here about fuel..... a std Stagea will run on 91 octane no problem. Unless you hear pinging from any engine (except if it has retarded ignition) then you are getting complete detonation.
And that means that it is OK. In fact you won't get any more power from higher octane unless you re-map and re-tune your engine, all higher octane lets you do is run more advance on the timing, higher compression or more boost.
Let us know when you're coming, we'll get a cruise happening.
Stagea is made to run on 100 octane. If you put a lower grade fuel in the ecu will adjust to avoid detonation but performance will suffer. Just remember when you get back to 98 to reset the ecu (disconnect it from power) so that it can adjust to the better fuel.
Well you won't get high!! if you plan on sniffing the opal !! :) but you could just take some octane booster with you to add to opal fuel like 104+ octane boooster :)
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
