Hi, I've got a r33 gts-t with a really annoying gearbox problem.
The main problem: When I'm stationary I can't engage 1st gear ( or any other gear) unless I really really force it. Once I've started moving I can go through the gears ok but as I come to a complete stop I need to put it back into 1st gear (when rolling quite slow) before I stop otherwise i won't be able to get it back into gear. Therefore I need to keep the clutch pedal in with the gear lever in 1st gear whenever I've stopped at a set of lights.
Other things I've noticed:
When the car is stationary and the clutch pedal is out there is a bit of vibration kind of noise. But when the clutch pedal is in the noise is gone (not sure if this is associated with the above problem).
Also, before the engaging gears problem occured there was always a pause of about 2 sec between when I put the clutch pdeal in completely and when the gear lever would go into 1st gear.
Also when the transmission fluid has warmed up it gets a little easier to put into gear but it still has the 2 second pause before going into gear.
Also if the engine is off then I can put it into gear very easily.
I've asked a few mechanics and they all give me different possibilities; transmission fluid, clutch, pressure plate, worn syncros. So i was hoping to get a few opinions before I pay heaps of money for a mechanic to waste time checking the syncros if its the clutch or vice versa.
I've got some redline lightweight shockproof gear oil (blue label) I'm going to put in.
Any help is muchly appreciated.
Thanks in advance
Sounds like you have a gearbox bearing problem. If it were clutch related you would be experiencing these problems in all gears. When you do eventually engage 1st gear, does it crunch going into it or no sound at all? If it makes a crunch then it's a synchro problem, if it doesn't then it could be the synchro hub or courtesy of the dicey bearing.
The two second pause between putting the clutch in and engaging 1st gear is quite normal, that is just the gearbox internals slowing down and allowing you to engage 1st gear. You can put it in gear when the engine is off and the car is stopped because there are no parts moving in the gearbox to lock you out of the gear.
Don't put in shockproof if you have the money to get your gearbox refurbished, it'll give you worse problems down the track.
In short, gearbox problem, pull her out for repair.
im assuming that the clutch and gearbox was working well before all this started happening, ie nobody has been playing with these parts
probably best to check the clutch master and slave cylinders before going through the trouble of pulling the gearbox out, a new master and slave used to cost $100 not sure about prices these days
When it finally goes into 1st it doesn't crunch - its just got a bit of a noise from the gear stick moving. So it must be the syncro hub or bearing then. But it does crunch from 1st to 2nd on the first shift every morning as if it needs warming up or something (possbily 2nd syncro is worn?)
Do you think the ticking (vibration) sort of noise when the clutch pedal out is related or would this be a different problem with the clutch?
Also do you think the shockproof would help in the meantime as I cant afford a gearbox rebuilt at the moment? or is shockproof only good for worn syncros?
Thanks :D
The clutch master and slave cylinders were changed just less than 2 years ago but it was working fine after this so i dont think it would be them.
Thanks for the advice anyway :D
Noises when the clutch pedal is out are rarely clutch related. When you let out the clutch pedal you start turning the input shaft, even in neutral, causing any problem bearings to start making noise. Crunch from 1st to 2nd first thing in the morning is usually a sign of a worn synchro, however it is quite common and if it only does this when the gearbox is cold then your synchro still has a fair amount of life left in it - to help with this first shift in the morning, either do it nice and slow (just hold the shifter gently resting against the 2nd gear gate until it pops in of it's own accord) or shift it fairly quickly.
Shockproof will silence alot of gearbox noises and vibrations...people mostly use it for synchros but it can mask alot of things. No harm in giving it a shot but start saving for that reco :D
  • 8 months later...
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
