  • Replies 75
Well, when i signed up i didnt know there already was a Miss 33, oops, sorry Miss*33, No im not a she male, last time i checked i was definately a girl. I know that info, bcoz my boyfriend is in the game himself! And my job pays very well for what i do, which is hardly anything. Maybe before, everyone starts shooting off saying im a she male or a clone, you all may want to get to know me a bit better. Who knows i could all save you thousands of dollars, when you need to fix your cars. Remember its who you know, not what you know!
:P no one got the joke about the job as head waiter sucking.....
Miss 33, sorry if I offended, and a belated welcome to the forums.
No one meant to offend, its all pretty friendly in here, and I suppose we overstepped the mark cos we dont know you. dont be put off though, everyone is very friendly here:)
Except hippy who likes bitch fighting:p
Turismo were a bunch of dorks anyway.
When I was shopping for a GTS-t, no one came out of the office to serve me. When I finally pulled someone out of their chair to help me, they weren't very informative. I asked to take one I was interested for a test drive, he replied "show me your cheque book and you can drive it". Idiots! How could they ever expect to sell a car that way.
Lost my sale.
Paul
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
