  • Replies 187
Hoodies are done... but at the factory!!!! grrrrrrrrr so i'll have them monday
I am working down at Marion on Monday, any possibility you could call into my work, or i call round and pick mine up? I don't finish till 5:30pm as that's when we close, so if you could let me know.
mebe... i'll see how things go, and if there actually done, or there "done"/stop harassing me... =\
i may or may not have received a call.... :P
if people really want them today i'll be having lunch at Ajisen Ramen on leigh st in the city around 2pm (very aprox time btw)
interstate guys, u'll be getting a pm from me later today
anyway possible for the hoodie to be posted? just give me your address with the post and i will send you out the $$ for the postage.....i only ask that as i am all the way here in Mt Gambier
hoodies are here and looking good!! :)
interstate people u have PMs :)
ahhhhh, u got msn or something?? might be easier to chat
edit: forgot to mention, how this friday at vilis for pick up??
This Friday is Christmas and Vilis is closed...but can still meet in the car park.
Should give Abe my hoodie aswell and ill see him sometime over the chrissy break.
ahhh crap!!! well, whos keen for later tonight then?? it's either that or wednesday...
can't tonight...been drinking, shall organize something for Wednesday night.
I shall pick yours up too and bring it down with me on Monday...if i get there.
Okay, heres the go:
will be at Vilis from 8pm to 8:30 on Wed 23rd for hoodies
also will try and duck my head in on thur the 24th to the jess/sinful thing
if you can't make either of those there will be the usual vili meets on a friday (cept this one apparently)
otherwise, let me know and i'll see what i can do
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
