The resonator helps reduce NVH from the motor making the car seem more luxurious/smooth. The z tube from US cars has no resonator though. Without analysing it too much, having any form of resonator should create a bit of turbulence and decrease of air speed which is not what you want for the car...unless of course you want it to be more quiet etc.
Ask Alan/Scathing, pretty sure he's taken his tube off before and noticed a small resonator on it.
https://www.sau.com.au/forums/topic/288251-z-tube/#findComment-4830751
Honestly, I would get one from the US. The US Z tube is better and being from the US works out a lot cheaper.
Shipping usually takes four days. I got mine from Riverside Infiniti, however there are other vendors out there, that are as good as if not better.
G35driver.com and Google are your friend.
As for install, seriously, 10mins with your eyes closed.
https://www.sau.com.au/forums/topic/288251-z-tube/#findComment-4830841
You don't even need to take it off to see it.
Here's the AuDM intake pipe on my car:
See that branch off the intake tube, just right of the strut brace? The one that seems to be a shortcut to the intake plenum in the photo, but in reality goes nowhere? That's the resonator.
Here's a USDM engine bay:
No "appendix" on the intake tract.
https://www.sau.com.au/forums/topic/288251-z-tube/#findComment-4831915
Dose a Z tube add any "real" power to the car? as in has anyone bothered to do a dyno test or anything... I just cant see there being much of a gain particually on a NA engine
Agreed. I dont know what the facination is with the "z tube". May as well just grab a proper aftermarket item, or leave the stock one there...
https://www.sau.com.au/forums/topic/288251-z-tube/#findComment-4834256
There is no real power gains from the Z tube as far as I'm aware. Its a cheap intake mod which reduces restriction compared to the factory V35 intake pipes and as a bonus it gives a more aggresive engine note above 3-4K RPM. If you get it cheap why not...if ur gonna pay $200 for it I say go but an aftermarket shiny one with pod filter.
https://www.sau.com.au/forums/topic/288251-z-tube/#findComment-4834263
I did all before and after test on my mods. Plenum spacer, Z tube and JWT pop filter. about 7rwkw on the spacer and another 8rwkw on the Z tube and filter
https://www.sau.com.au/forums/topic/288251-z-tube/#findComment-4834478
SO what ur saying is that the spacer was good for 7kw on its own
and then with a filter + the x tube it was good for another 8kw? was this done on the same dyno on the same day @ around the same time as 8rkw from just a ztube and filter sounds like a big gain for what they are
so in total you netted an aditional 15rwkw by having the spacer the ztube and the filter?
https://www.sau.com.au/forums/topic/288251-z-tube/#findComment-4834502
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
