For Sale: Set of 6 Hks 550cc injectors. Low impedance. Just removed from a rb26. In good working order.
Price: $500
Contact details: email: [email protected]
Extra Info: will be a direct fit for rb20's as well, need resistor box tho.
Pictures:
https://www.sau.com.au/forums/topic/288436-hks-550cc-injectors/
  • 3 weeks later...
  • 3 weeks later...
Correct me if im wrong..
These can fit my RB20 but i need the GTR Balast Resistor ?
good price...
Don't worry dikhead like me didn't read the ad properly :thumbsup:
Edited by v8tzr
