hey peeps up for sale are some r33 series 2 parts from wreckage. cleaning out my shed of unwanted stuff.
- Front and rear standard r33 sway bars, make me an offer comes with all bushes and links.
- Starter motor looks average make me an offer.
- Shimmed standard diff by boss, feels very tight, appears not to be welded, i never drove the car with the boss diff, iv had the back plate off it looks to be in really good condition. an its an ABS diff is that helps. $450 ono. will fit r32 all u need to do is change the back plate over.
- R33 s2 hicas pump and rack ends $150
- R33 front 5 stud hubs $150 pair. one sides missing a stud or 2.
- R33 sub-frame good condition, very straight $200 good cradle bushes comes with traction arms and rear hub mounts.
- Brake master cylinder excellent con look brand new $150 ono
- Clutch master cylinder good con $150 ono
- Manual r33 tail shaft ok condition needs new center bearing, easily fixed. $200 ono
- front engine cross member $200
- Power steering rack $200 with rack ends
- R33 handbrake leaver make me an offer.
- r33 front and rear standard reo's bars, fronts been cut for cooler, rears standard. $80 each.
- Power steering pump make me an offer rb25det.
- Standard under engine dust plate good con make me an offer.
- Indicator and wiper stalks make me an offer.
- black rear pods $150 for both
- Minter petrol flap black in color $50
- 3" decat pipe stainless steel $100
more to come thats all i can think of for now
all itesm are off a r33 series 2 Rb25det.
pm me or sms me on 0421675373 with interest, dont call i wont answer whilst im at work.
cheers BEN.
https://www.sau.com.au/forums/topic/288900-wrecking-r33-series-2-rb25det/
Hey all, update on parts, no boot lock, climate control unit, no turbo, no air box, no shifter surround, no seats.
sorry.
As for the reo's id rather have them bought locally as i cont have a courier etc. easier for me.
Last but not least the link pins for the front sway bar id rather sell as a kit with the bar, other wise it will prob just sit here for ever.
cheers BEN.
Edited by BENDERS32
quick update with parts that have been sold:
r33 front and rear standard reo's bars, fronts been cut for cooler, rears standard. $80 each. SOLD
cheers BEN.
what i have listed is all i have left thanks peeps.
  • 1 month later...
hey peeps up for sale are all the r33 series 2 parts from wreckage that i have left. cleaning out my shed of unwanted stuff.
cheers BEN.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
