hey peeps up for sale are some r33 series 2 parts from wreckage. cleaning out my shed of unwanted stuff.
- Front and rear standard r33 sway bars, make me an offer comes with all bushes and links.
- Starter motor looks average make me an offer.
- Shimmed standard diff by boss, feels very tight, appears not to be welded, i never drove the car with the boss diff, iv had the back plate off it looks to be in really good condition. an its an ABS diff is that helps. $450 ono. will fit r32 all u need to do is change the back plate over.
- R33 s2 hicas pump and rack ends $150
- R33 front 5 stud hubs $150 pair. one sides missing a stud or 2.
- R33 sub-frame good condition, very straight $200 good cradle bushes comes with traction arms and rear hub mounts.
- Brake master cylinder excellent con look brand new $150 ono
- Clutch master cylinder good con $150 ono
- Manual r33 tail shaft ok condition needs new center bearing, easily fixed. $200 ono
- front engine cross member $200
- Power steering rack $200 with rack ends
- R33 handbrake leaver make me an offer.
- r33 front and rear standard reo's bars, fronts been cut for cooler, rears standard. $80 each.
- Power steering pump make me an offer rb25det.
- Standard under engine dust plate good con make me an offer.
- Indicator and wiper stalks make me an offer.
- black rear pods $150 for both
- Minter petrol flap black in color $50
- 3" decat pipe stainless steel $100
more to come thats all i can think of for now
all itesm are off a r33 series 2 Rb25det.
pm me or sms me on 0421675373 with interest, dont call i wont answer whilst im at work.
cheers BEN.
https://www.sau.com.au/forums/topic/288900-wrecking-r33-series-2-rb25det/
Hey all, update on parts, no boot lock, climate control unit, no turbo, no air box, no shifter surround, no seats.
sorry.
As for the reo's id rather have them bought locally as i cont have a courier etc. easier for me.
Last but not least the link pins for the front sway bar id rather sell as a kit with the bar, other wise it will prob just sit here for ever.
cheers BEN.
Edited by BENDERS32
quick update with parts that have been sold:
r33 front and rear standard reo's bars, fronts been cut for cooler, rears standard. $80 each. SOLD
cheers BEN.
what i have listed is all i have left thanks peeps.
  • 1 month later...
hey peeps up for sale are all the r33 series 2 parts from wreckage that i have left. cleaning out my shed of unwanted stuff.
cheers BEN.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
