ITEM 1 dont know what this is called but i know i need it
ITEM 2 item one came out of this part of the rb20 diff. as you can see i broke the plate which has bolt holes in it
ITEM 3 this is the rb25 sump+diff.
im doing a stagea rb25neo into r32gts4 swap
what im trying to do is put the rb20 4wd sump onto the rb25. Because i need to have the same ratio as i have in the rear diff.
my questions are:
how does item 1 stay in the diff?
is it meant to slide in and out of the diff freely?
and can i replace the broken plate on the rb20 diff with the plate off the rb25?
thanks
The shaft should be held in by a spring circlip. (I think what you have is a dummy shaft to stop oil spilling out)
Why not just swap the actual diff centre and pinion gear from the RB20 to the RB25?
LOL @ i dont know what it is but i know i need it! :(
Item 1 is your front driver side CV input shaft. The "spine" end goes onto the diff and is held with a circlip as mentioned above. The other end is meant to have a cv boot over the top where the CV joint and shaft goes to, then the shaft obviously goes to your driver front wheel. The circlip is an absolute prick to get off and your need to lever the shaft out of the diff, which it looks like you did but broke the little alloy plate on the end...
So answers:
The spine slides into the diff
No its not meant to slide freely, the circlip holds it in place. Once in place it wont come out without alot of swear words.
Yes the plates should be interchangeable (99% of the awd stuff is the same between, gtr, gts4, gtfour etc), just dont break the one on the rb25neo..
Also get new CV boots while you are there. The tear with age and they are a prick to change.
Edited by R34GTFOUR
item one has a circlip on the end of it so it clips in and doesnt fall out. if its missing any driveshaft shop should have one. ps.. make sure it not sitting in the the diff centre..
item two is a straight swap but swap the bearing cone from the damaged one over and all the shimms with the dammaged one. (critical too keep the factory backlash and bearing preload.)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
