making this thread as the old one had like 6 pages and no one knows whats sold..all parts in sydney..
Nismo 320 KM cluster (20,000km) 650$
HKS in tank fuel pump 320$
Nismo Clutch Pedal Bracket 110$
Defi Link Meter Boost + Defi Control unit 2 300$ (green lighting matches nismo cluster perfect)
HKS type 0 turbo timer 80$
HKS type s intercooler + piping to suit trust plenum plazma man etc etc 300$
rb26 rocker covers + hks badge 500$ powder coated blue+clear
C.e.s Racing split dump pipe rb20-rb25 450$
HKS Silent hi power cat back 600$ (comes with free HKS removable silencer)
Nismo engine + gearbox mounts (hicas) 200$
veilside combat sideskirts r33 200$
2 pak silver dash + shifter surround 200$
Momo millenium wheel + boss kit for r33 200$
momo pedals (fit over stock ones) 60$
sfs hoses 80$
genuine Cusco catch can + custom breather 70$
hks seatbelt pads 20$
top secret front bar r33 gtst 200$
https://www.sau.com.au/forums/topic/289007-stripped-r33-aftermarket-leftovers/
  • Replies 42
sfs hoses 80$
ill take the catch can,im in tassie if you could post [email protected] or 040899357 cheers
hey im liking the s2 dash and gear surround but will only be able to offer $50 for it if there are no scratches on them (mine are silver, but s1 with scratches)..
No insult intended, just broke ass unemployed uni student..
Cheers
Edited by FLT10
Cheers
sorry mate....its a proper job i cant let it go for 50$ the dash is worth more alone..
sfs hoses 80$
Hi mate condition are the Nismo engine / gear box mounts if in good condition how much to Melbourne?
10 bucks shipping included?
i asked some1 in perth just tonight ill see if he gets back to me soon,
can you hold it for a few days??
i dnt think its a part in high demand:p
yeah mate ill ship it for nothin..its tiny and light..its actually at my mates..hes gonna drop it by this weekend...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
