making this thread as the old one had like 6 pages and no one knows whats sold..all parts in sydney..
Nismo 320 KM cluster (20,000km) 650$
HKS in tank fuel pump 320$
Nismo Clutch Pedal Bracket 110$
Defi Link Meter Boost + Defi Control unit 2 300$ (green lighting matches nismo cluster perfect)
HKS type 0 turbo timer 80$
HKS type s intercooler + piping to suit trust plenum plazma man etc etc 300$
rb26 rocker covers + hks badge 500$ powder coated blue+clear
C.e.s Racing split dump pipe rb20-rb25 450$
HKS Silent hi power cat back 600$ (comes with free HKS removable silencer)
Nismo engine + gearbox mounts (hicas) 200$
veilside combat sideskirts r33 200$
2 pak silver dash + shifter surround 200$
Momo millenium wheel + boss kit for r33 200$
momo pedals (fit over stock ones) 60$
sfs hoses 80$
genuine Cusco catch can + custom breather 70$
hks seatbelt pads 20$
top secret front bar r33 gtst 200$
https://www.sau.com.au/forums/topic/289007-stripped-r33-aftermarket-leftovers/
  • Replies 42
sfs hoses 80$
ill take the catch can,im in tassie if you could post [email protected] or 040899357 cheers
hey im liking the s2 dash and gear surround but will only be able to offer $50 for it if there are no scratches on them (mine are silver, but s1 with scratches)..
No insult intended, just broke ass unemployed uni student..
Cheers
Edited by FLT10
Cheers
sorry mate....its a proper job i cant let it go for 50$ the dash is worth more alone..
sfs hoses 80$
Hi mate condition are the Nismo engine / gear box mounts if in good condition how much to Melbourne?
10 bucks shipping included?
i asked some1 in perth just tonight ill see if he gets back to me soon,
can you hold it for a few days??
i dnt think its a part in high demand:p
yeah mate ill ship it for nothin..its tiny and light..its actually at my mates..hes gonna drop it by this weekend...
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
