  • Replies 51
Looks like I should be able to come, my boss told me I am not going to Townsville.
Scratch that, I got told today that I am now going to Townsville and I'll be away for the 22nd. Bugger!!!
Ok, so here's the issue as I see it: The recce runs aren't so much a problem: I have nothing but time on my hands these days, so I am able to go far and wide to find some good roads if needed, and there's been plenty of offers from you Northern guys to do the same...
The endpoint is important: I've been on a few cruises now, and it's the endpoint that generally makes or breaks them: the last one was good because it was free of any public/crowds, had bathroom facilities, shade, and plenty of seating...
Those of you who were on Darrin's go-karting cruise would agree: the endpoint in that one was great for the same reasons (and it had pluto pups and go karts as well!!)...
I am more than happy to organise another southern run, finishing either at Myles' place again (assuming he's ok with that), or my place.... Alternatively you Northern folks can start putting some thought into suitable places to finish up, and we'll do the whole shebang up your end... :)
Let's aim to have a decision made by the end of the month: that way we have plenty of time to finalise the route, etc... Shade will be especially important for this next cruise, as it's not going to be getting any cooler in the near future....
I'm going in for a shoulder reconstruction on Nov 9th, I am not allowed to drive for a month, doctors orders, so no insurance etc. If my L plate son thinks he can handle it I might get there, otherwise its wait till the next one.
When the route is laid out my son and I can do a test run so he knows the way.
At this stage, it looks like being down this way, if not the same run we just did (but in reverse, maybe?)... Since I have stupidly promised a mate to run his business for him while he traipses around Europe, I'm way too busy to do a Northern recce run, but will see if I can find another interesting route locally...
That is of course unless someone else has done some groundwork up North??
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
