OK... I have the following for sale.
'03 Model XBOX. Extensive Modifications! Goes well, unrego'ed... roll cage etc. 2 controllers, all leads etc.. $200 (and yes.. it is modded). **SOLD**
2 year old TAMIYA TA03F RC car... 3 shells, WRX 2 Dr, Pug 406 and an R34 one that i kinda screwed up.. :) has a few extras but needs a rebuild and clean (full perfect working order!) electronic speed control (unused) extra pinions (unused) CRAZY motor (i believe its a 16 turn.. cant remember - also unused), all radio gear, 2 sets of rims (doorifto stylez). AWESOME car.. the only reason i'm selling is cause i just dont have time to drive it.. i am looking for around $350+ for this as the engine ESC and wheels are unused and cost me $200 just not long ago and the car + radio gear was $550.. it owes me a bit and prolly only has 5hrs on it.
N64 with 2 conts, memory card, 2 rumble packs (1 un-genuine) and NHL98.. i sold the other games... $50
CRAP LOADS of HOT4's and Fast Fours.. tell me if you are after a certain issue number.
Dell Laptop bag - $5
Vid camera bag (virtually brand new) - $10 (was like $60 not long ago)
my decks :rofl: 2x SL1200 MK2 Technics t/tables w/ a Numark DM2002X mixer... $1000ish (If i dont get what i want - i will keep them.. its hard to let them go. :rofl: )
pc subwoofer and speaker set $30
Logitech Wingman joystick $30
there'll be more soon.... jack of typing.
PM or email only puhlease
Christian
https://www.sau.com.au/forums/topic/28930-bits-n-pieces-for-sale/
Do you have any details on the PC Speaker set? Brand/Pictures/Specs etc.
brand is Juster - i'll send pics when i get home. Its a sub and 2 speakers that plug into the sub.
Christian
