Hi Lads,
Hooked up my AVC-R and discovered that it won't go past factory boost.
I have my actuator (solenoid) COM side connected to the wastegate actuator, and the other side has been plumbed via a tee-piece to be from the manifold (bottom line that passes underneath the throttle body). My pressure sensor is also plumbed between my plenum and factory BOV pressure line. Is this severely wrong?
I have heard some people have used the pressure hose to the carbon canister to plumb to the solenoid, and tee-pieced the pressure sensor between the plenum and pressure regulator (where boost gauges are plumbed).
Could this be a big issue for me? I would assume that these would be measuring the same pressure. Does anyone have any comments, your help would be greatly appreciated.
https://www.sau.com.au/forums/topic/28952-avc-r-connection-question/
Have you plumbed NC or NO (from the soleniod)? Also, did you remove the plastic bung in the spare (NC) hole of the solenoid.
Generally with boost controllers or map sensors, try and plumb them as close to the source of boost as possible, mine was running from the crossover pipe for the intake, which worked ok, but you will need to drill a hole and fit a hose tail connector.
do you have an english manual? If not, the apex usa site has a downloadable PDF.
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
