Hi fellas,
My clutch shat itself (It was a Jim Berry Full Monty clutch), so I sent my clutch and flywheel back to Jim, in exchange for a reconditioned used clutch and flywheel, paying him $550.
Now, I just have a few concerns which you fellas might be able to give me a hand with.
1) When I sent the clutch and flywheels to Jim, it wieghed 16.5 kg, when I received the reconditioned flywheel and clutch back, it weighed in at 19kg?? Just wondering why the increased wieght, it's not that much more, but in terms of % increase it is? COuld jim have given me a different flywheel?
2) I took it to a shop here in canberra for the clutch and flywheels to get installed, when I picked up the car, I noticed a loud rattling sound coming from the clutch. I asked the mechanic what the deal is with the sound, he said it was my power steering, however, I could clearly hear it was coming from the tranny somewhere.... Now I don't know what to do, should I give Jim Berry a call and ask him what it might be, or get the mechanic to fix his possible poor installation?
I have a R33 S2 GTS-T.
THis car is an endless pit, soo much time and money invested into the thing only to give me more head aches.
ANyway fellas, any help would be appreciated.
Have a great w/e, cheers.
https://www.sau.com.au/forums/topic/289555-help-needed-clutch-issue/
I assume your original flywheel had been 'lightened', not the best idea for a stock flywheel so your better of with the full weight original from a safety perspective despite the performance compromise.
I would seriously consider going with a proven clutch from npc or most of the jap brands. The $ up front are saved down the road.
Is the rattle when the clutch is in/out or engaged and driving?
Ok, thanks for the advice. I've heard from around these forums that the Jim Berry Full Monty clutch is the best way to go?
ANyway, the rattle happens when the car is in neutral and stationary. It happens when the clutch is out, but then the rattle comes and goes as it pleases, if you give the car a rev, the rattle disappears, then comes back after like 15 seconds....
This sounds like a gearbox rollover noise to me.
If it disappears when you put the clutch in and the vehicle is idling in neutral then it is almost certainly gearbox.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
