just a quick post until i have time to upload pics
as the title says i have a 7 point cusco safety 21 roll cage for sale was fitted to my r34 but have changed my plans
looking at $600 ONO
ill try to get pics up tommoro
tom 0401035221
fitted to a r34 but suits a R33.......when it was fitted to a r34 the rear legs are a different angle to the rear wheel arches so custom adapters where made they are not included in the sale
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
