these parts are just sitting in the garage not needed
2 x Micky Tompson ET Street Radials
275/40/R17
WITH 350Z 17" RIMS
blemished
Have been used approx 7 runs.
see pics for condition
$400
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
R33 GTS ser1 rear wing
looks like its been repaired
$50
R33 GTS rear wing GTR copy-USED
with brake light & carbon fibre end plates
$250
R33 ser1 GTS JUN style front bar
Never been fitted/holes yet to be drilled
MINOR BLEMISH FRONT BOTTOM SEE PIC
$250
GReddy Profec B Boost controller
WITH INFRARED STEERING WHEEL MOUNTED BOOST SWITCH
$300
IVE GUESSED THE PRICES SO IF IM OFF THEN LET ME KNOW AND SOMTHING
MAY BE WORKED OUT
PARTS LOCATED IN LIVERPOOL SYDNEY
0430 101 863
pm for details
https://www.sau.com.au/forums/topic/289994-car-parts/
  • 5 months later...
Rims & Tyres $250
GTS Wing $15
GTR Copy wing $150
Jun Style front bar $170
pic of what the finished product could look look like.
gotta get this stuff out of the garage .....................
0430101863
Edited by leg46y
https://www.sau.com.au/forums/topic/289994-car-parts/#findComment-5172590
  • 1 month later...
PRICE DROP
Rims & Tyres -SOLD
GTS Wing - FREE WITH GTR WING
GTR Copy wing $150
Jun Style front bar $150
ITEMS OFFERED FOR PICK UP ONLY.
SORRY BUT I DONT HAVE TIME TO MUCK AROUND WITH POSTAGE.
APOLOGIES TO THE INTERSTATE BUYERS
Edited by leg46y
https://www.sau.com.au/forums/topic/289994-car-parts/#findComment-5308271
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
